Hi guys,
after reading this biiig thread, i'll add my personal experience and I will also ask for a piece of advice you.
I ride a '07 F800ST, graphitan with 64.000km. It has Ohlins inside the front fork, HID and (here's the important part) a K&N filter and and Akrapovic titanium exhaust.
I removed the CAT when I fitted the K&N and the first thing I noticed is that, as somemone told, the bike "breathes better". When i say "breathe" I mean the bike is like it has more power in lower revs. I can easily use 6th gear at 50km/h. Not sure if the cause is the K&N or the removed CAT. The bike is simply 'easier' to ride, in terms that the engine allows you to be more 'lazy' in terms of gears. It has increased acceleration (with the baffle out) and fuel economy is about he same. I can roll at 120-130km/h, packed and with my girl as the OBC shows 4.5lt/100km.
Regarding to filtering "worse" that others, it should be true, i guess... It if lets more air flow, the air must go through somewhere lol... Tiny holes. Lots of them. The thing is I don't use my bike offroad (it's a road bike...) and I don't get a lot of dirt where I ride. Most hazardous 'bit's' get sticked in the oil, you just gotta make sure you keep it clean and perfectly oiled. Not too much , no too less oil.
1 thing I noticed and I'd like to hear from you guys. It backfires. Omg it backfires like it ate like a full stock of tacos! When I pop down a gear or when I simply shut the gas. I've asked a friend and he says that I should take the bike to a dealer and take a look at the ECU, because the 'popcorn' I hear inside the pipe is gas which didn't burn when i shut the throttle. My question is, shouldn't the ECU adjust itself? I also hear it has a certain threshold from which it can't adjust anymore. Makes sense, since I have my exhaust line fully open.
Oh and the bikes keeps dying on me, when already hot. I've reprogrammed the air valve, but it keeps doin' the same thing
Any words of wisdom?
Ride safe!
