It started with instrument panel LCD display going blank when riding some 50 km/h and then returning to normal when slowing down to 1st gear.
Over the last few days the problem has had different variations, but in general heads lights fail, LCD display going blank when riding, turning signals not working, speedo needle showing zero no matter what speed I ride.
Engine running fine so far!
BMW dealer did not find the fault and returned the bike. The bike was fine for about 5km after which the problem reappeared.
Took the bike back to dealer who run the tester showing few voltage failures in the memory (ABS: Voltage supply, DME: voltage supply, Instrument panel: voltage supply etc).
They did not have time to reopen the bike for more checking and had no idea what is causing the problem.
Until tonight the problem only appeared when the bike was moving, but just now noticed the instrument panel LCD going blank after running idle on centre stand some 5 min. When applying turn signal switch or switching handle bar heater on the fault disappears only to return after one or two minutes....
I did open the ZFE and ECE connectors and applied some CRC, but no help.
Anybody had this kind of experience?
