What is this part and where does the pipe go?
1 reading
92 views 5 replies 4 participants last post by  Stringman
Hi all
Fitting the AF xied I had to move the ecu and a few other bits to get access to the connector.
In front of the ECU is a plastic cylinder as in the photo.
When I moved I noticed that one of the pipes (on the left hand side had possibly been disconnected.
The two pipes on the right (connected) say purge and tank. the one on the right (not connected says air.
Anyone have any idea what the part is and if the pipe does connect to anything?
Thanks in advance
#2 ·
That looks like the charcoal canister to me. It should be connected to the fuel tank breather and the FI air intake hose so that when the bike is started it can suck out fuel gases from the canister and into the fuel injection's air intake system.
#4 ·
I believe that single hose at the bottom is a drain in case the canister gets filled with raw gas, such as if the fuel tank is overfilled on a hot day. If that happens it will drain the gasoline to the pavement under your bike. But then your canister will likely not work properly and will have to be replaced because the filter medium will be clogged and it will no longer vent your tank. If you lived in the U.S. you could just remove the thing and vent the tank to the atmosphere. However, I am not sure if you could get away with that in your country.
