If it's only a spot, and not getting worse, (no bigger leak, and oil level not dropping) I'd carry on as is, and keep an eye on it.
I would re-do the torque settings though when the engine is warm, and see if that helps to nip up that seal.
Is it definitely coming form there, and not potentially running down/across from elsewhere? The talcum power test is good to show the trace of it.
