Traction control f700gs
364 Views 9 Replies 6 Participants Last post by  308bever
Hello I have a problem on my f700gs of 2012 !! I can only deactivate the ABS with a button but not the ASC (traction control) I'm sure I have this option because the bike loses power every time I try to lever can you tell me where the cable due traction control thanks!! Sorry for the faults. I am French.
1 - 10 of 10 Posts
I wasn't aware that the F700GS models offered traction control as a factory option. :unsure:
Pourtant c’est sure ! Même en vitesse 1 elle ne se lève pas. une perte de puissance quand la roue avant ne touche plus le sol mais aucun bouton pour le désactiver je cherche ce fameux câble pour le débrancher
Traction control is called "ASC" by BMW. It is disabled by the rocker switch above your turn signal switch. Just push it up and hold until the light indicates on the dash (triangle inside a circular arrow). ABS lights up a different symbol on the dash when disabled using the procedure, but ABS can only be disabled when stopped. ASC can be toggled while moving.
F700GS Rider's Manual - Deactivate ASC function
French version
Merci pour la réponse mais le problème c’est que j’ai que le bouton pour enlever l’ABS j’ai essayer de maintenir ce bouton mais rien n’y fais. C’est pour cela que je cherche le câble pour directement le débrancher je suis sur d’avoir l’Asc ma moto est débridée et mee en première vitesse avec un appel d’embrayage elle ne se lève pas c’est obliger qu’il y ai l’Asc
This is spam. Nonsensical content for a bike that does not exist (2012 F700GS).
De quoi tu parles ?
[/QUOTE]
I'm not so sure, there is a user manual available on the official BMW sure for 6/12 onward F700GS and that manual has instructions for ASC.
That said, the switch pod communicates over the CANbus and there isn't a dedicated wire for the ASC switch. Either the switch has bad contacts or they need to plug the bike in and check that the switch is recognized and if there are any codes.
my 2013 f700 has it, same button as abs.
1 - 10 of 10 Posts
