There were two drain/breather holes in the bottom of the lens I used those.Did you drill the top of the taillight to run the wires through?
I contemplated doing that, but it would have meant chopping into the original wiring. I felt the route I took was a lot less invasive.Isn't it possible to make a less invasive connection by intercepting the electrical system under the saddle?
