1 - 3 of 3 Posts
· Registered
Discussion Starter · #1 ·
been an expensive 2023 so far for my brother and his st. im the designated motorbike mechanic so labour is free for him, but parts costs definitely add up.
started with his belt shearing off multiple teeth leaving the bike stranded and needing to be trailered home. luckily he had aa membership.
cost was £140, and managed to fit it in the dark with a few torches.
Tire Automotive tire Wheel Tread Automotive lighting
Automotive tire Road surface Rectangle Wood Asphalt
then he faniced getting hyperpro springs, so fitted them a few days ago. no pics as it was just the same thing as changing seals with less steps.
while changing the springs, noticed his rear pads were non existant and the disc was badly scored.
with rear discs being around £100, managed to find a used genuine disc with 5mm thickness from a 2000 mile r ninet for £39. ebc fa213 pads ordered for £14, and fa244v for the front for £29 as they look like theyll need doing soon enough.
stripped the rear brake, regreased the sliders, cleaned the piston and it pushed back nicely. managed to remove 4 of the disc bolts until the last one rounded. tried a torx extractor, that didnt work, so had to go to town with the dremel. not a fun job but it came out in the end. just waiting for 5 new bolts from motorworks now.
Automotive tire Rim Bicycle part Motor vehicle Automotive wheel system
Brown Wood Flooring Ceiling fan Floor
· Registered
Glad to hear that you got the bolt out. I hate how something like that turns a 30 min job into a all day affair. They're only supposed to go on at 20 Nm, so they must have been pretty corroded.
I changed my rear ones out last year and went with the Chinese made Arashi rotor for only $55USD and EBC FA 213HH pad for $35. The rotor looks better than OEM and feels great with the EBC pads. IMHO Arashi pads are worth considering and are certainly hard to beat on price.
· Registered
Discussion Starter · #3 ·
theres a receipt from the po of the rear disc and pads being changed around 2017, so i have a feeling a gorilla tightened them up as there was no way they were 20nm.
just read up on arashi discs, they seem very well rated online. price wise they are about 40% cheaper than ebc or brembo rear discs, definitely one to keep in mind if the fronts ever need doing. cheers for that
1 - 3 of 3 Posts
