1 - 11 of 11 Posts
· Registered
Discussion Starter · #1 ·
Hi all, I found a '16 F800Gt locally with 6 miles on it that's tempting. The only think not on my wishllist is a quickshifter.
Save for new ti(y)res, it's stone stock. I'd need a top box, driving lights, Vstream and...fill in the blank for other needed mods or farkles if you had to start over again, thanks.
· Registered
6 miles means it probably hasn't had maintenance done.
Brake fluid and antifreeze will need to be changed.
Fuel components may be gummed up.
I wouldn't trust the battery. Check the date codes on the tires - replace if 5+ yrs old.
You'll need to have the dealer do the 600 and 6,000 mile services.
What vibration?? The F800s have an extra throw on the crank w/ a short, rocking arm that balances the engine out very nicely. see PARALLEL TWIN ENGINES | Motorcyclist (motorcyclistonline.com)
· Registered
Discussion Starter · #6 ·
True enough, Lithium battery, certainly tires as these are originals, all fluids, likely close to $1k-usd at the stealership.
And every test repost I've read mentioned high rev vibration in the seat and bars, more than most P-twins they say.
· Registered
Discussion Starter · #7 ·
So like a virgin in a pole dancing club, my head was spun to a GS locally, a bit like seeing someone who looked like your 1st GF. Starting out in MX, this seems more like what the F800 was meant for.
Anyone with a GS wished they'd bought something else? I'll be tooling around boring flat Florida with the rare 100+ mile jaunt. The owner of the one I saw rode it on 500 mile trips out west and loved it.
· Administrator
Garage cream puff, 10k on it.
Is there trick to uploading pics? I even cut loose my VPN and all I get is error messages....
Click on the paper clip icon below and you can post pictures from your computer files.
Reactions: houseofcharm
1 - 11 of 11 Posts
