Hello,
I own a BMW F800ST and recently noticed a metallic knocking / clunking noise when the bike is idling in neutral.
Here are the details:
Possible causes I’ve considered:
I’d like to confirm the source of the noise before it causes further damage. What would be the recommended diagnostic steps for this model?
Thank you in advance.
- The noise is most noticeable at idle, especially when the engine is warm.
- It is a periodic “tok/tok” sound, not a constant scraping noise.
- When I pull the clutch lever in, the noise changes (sometimes reduces or disappears).
- The sound seems to be coming from the right side of the engine (clutch / transmission area), not from the cylinder head.
- Performance and gear shifting feel normal, but I’m concerned about potential wear or damage.
- Clutch basket wear (play in the basket fingers)
- Worn or failing clutch release bearing (throw-out bearing)
- Primary drive gear play or transmission bearing wear
- Less likely: camshaft or valve train noise (as the sound is lower-pitched)
