I would think that the plug is the same as the GS which takes a 16mm socket.
Well the tunnel is designed for a 16mm plug and given the small bore you will never find a 18mm socket that will fit. You bought the wrong plug.Thanks for your reply, I checked with Autolite and they say 18mm. (I did try a 16mm, though, no luck)
Thanks, I thought that would be a tough one being that sockets are made of hardened steel. I don't have a grinder, but if it were easy, I have a friend who has one.I took a deep socket to task at the grinder years ago and made my own “custom” thin-walled spark plug socket which I’ve used ever since. Was not difficult. I realize that if you do not have a grinder, that info is of little use, but just in case I thought I’d mention it.
Sent from my iPad using Tapatalk
Thanks for getting back. If that's the case, I have a bigger problem-getting those plugs out, oof.Well the tunnel is designed for a 16mm plug and given the small bore you will never find a 18mm socket that will fit. You bought the wrong plug.
Hi Richard,Have you looked at Amazon for a long thin-wall spark plug socket? I recently bought one for my R1200RS and they had a number of them, including a bunch of coil remover tools.
Ordered!I suggest the NGK DCPR 8 EIX.
