Instrument panel capacitor swap
1011 Views 1 Reply 2 Participants Last post by  Kukopia
The digital clock on my panel has been off for a while, even after changing the battery and readjusting it several times.
Recently I had the dashboard turn on spontaneously in mid-ride, or on the way back after the bike has been turned off for a few minutes.
In this thread -
They solved a similar sounding problem by switching out the 100uF/16V capcacitor of the panel's board.
I understand that a 100uF/25V capacitor might be more resilient than a 16V, but it's a little larger as well , got both just in case-
Thought I'd disassemble it, take it to an electrician with both capacitor types, and ask him to replace.
However, I can find no instructions in Haynes / online as to how to remove the panel on the ST.
Was hoping for a hint - do you go through removing all the front fairings and headlight, or is there a quicker way with some proper tools?
