Normally the bike activates its fuel pump for about 2 seconds when you put the key switch to "ON",
so when you press the ignition button fuel pressure has already been build up.
My bike no longer does this.
It only starts the pump together with the ignition button en keeps running fine as long as the engine is running.
There are no active fault codes (using a gs-911 diagnose tool to read)
The pump also runs fine when activated manually (using test mode from the same gs-911)
It's been like this for the last 10000 km's and doesn't change.
The bike runs well, but it just takes 1 to 2 useless (extra) cranks to start it because it still needs to build up fuel pressure.
Anyone who has an idea why?
