1 - 5 of 5 Posts
· Administrator
Discussion Starter · #1 ·
· Registered
I've had those tires on the f8 since the beginning of August, for about 5000 miles now. Great handling, grip and feedback. Just soft as butter and fast wearing, except the front that seems to last. As far as the rear is concerned I'd be happy if I could get another 2 to 3000 miles out of it.
Especially with luggage (about 60 pounds and my lardy 300 pound weight) a bit prone to squaring.
Picture taken after a very spirited ride on my favourite road. About 3 hours after mounting the tires. So the grip and confidence is definitely a big plus!
Tire Wheel Helmet Automotive lighting Bicycle tire
· Administrator
I've been a fan of the Conti RA3 tires for several years now. The feel seemed just right going into a turn, holding the line, and later going straight they held that as well without requiring corrections. I suppose the best thing you can say about a set of tires is when you don't think of them at all when going into high-speed turns. Another advantage to Continental tires is the road hazard warranty that comes with the tire purchase.
I did find it interesting to note the difference between the RA3 and the new RA4.
Triangle Font Symmetry Rectangle Parallel
As they said in the article, you'll never find out who competitor 1 and 2 are. Probably some artistic license used there. ;) What I do get out of the graph, is the difference between the RA3 and the RA4 is minimal. So if the tire price ends up going much higher for the RA4, it would probably be wise to pick up some RA3 tires and keep them in the garage.
I have to put in a plug through for the Bridgestone T32 tires. As much as I've liked the Conti RA3 in the past...I like the T32 tires even more. Wet and dry grip are great. The feel is perfect. And the smoothness on the road brings a smile to my face. At at least $40 less for the rear tire alone, I'm going to the Bridgestones in the future. I don't feel like I'm giving up anything by using the T32s.
· Registered
I have been using Pirelli ST GT and GT2 for years with a preference for the GT. The Pirellis are tires that have always given me confidence, but I'm intrigued by Continental and would like to try them.
· Registered
I had always been a Michelin man, but I took the leap of faith this past spring and put on a set of road attack 3's. I love them. I wanted the 4's but they weren't available. I did about 7000 miles on them this year and they still look and feel almost new. Maybe a hint of a flat spot on the rear, but I did an iron butt ride of all freeway in the hot summer. That certainly will put a flat spot on any tire.
Sent from my SM-G991U using Tapatalk
1 - 5 of 5 Posts
