Hi folks, I just changed all my brake pads and rotors, back brake is fine, so is the front - until I start the engine, then the lever comes back to the bar unless I pump the lever, but even then it losses pressure quickly. Any suggestions? Tia
Ah I was hoping there wouldn't be a "special' tool required, I took it in for it's mot, the mechanic bled the system and got air out, but it came back - there's no fluid leak that either of us have seen, so hopefully it's just something simpleAs I recall, the GS-911 diagnostic tool has a service function that will exercise the ABS system (normally done after bleeding the brakes). Look into it 🏍
That's a really good tip, I think I first used that trick on an ER5 - unfortunately it didn't work this time, I tried that before taking it to the garage - but thanksTry leaning your bike on the side stand, tighten the brake lever as much as you can, then wrap a tie around the lever and bar grip to keep it pressing on the brake and leave it overnight. Sometimes that can help to get any air out of the line.
