Hi all,
I've just ridden the bike to work. The battery was suffering from lack of use in the miserable weather we've had recently so I thought I'd give it a run as it's cold but dry here.
Anyhoo, I rode about 5 miles to get fuel before continuing on another 7 miles or so to work. Everything was fine before the fuel stop but afterwards I almost immediately got the red triangle and flashing temperature gauge. I've had this happen a few times before and just ignored it because I have checked the fan and found it works consistently when needed. Also, the warning seems to clear after a few minutes of further riding.
This time however, the warning didn't clear and it was still flashing away when I reached work and parked. The fan was running, I could hear it.
So, coming home last night, the temperature outside was between - 1 and 2 degrees C.
Rode all the way home without stopping and got no warnings at all.
I'm trying to understand which part of the system is playing up. It only seems to happen if I ride a short distance, stop (engine off), then resume the ride.
If it's a faulty sensor but the fan is coming on, then there's not really a worry of damage to the engine. If the thermostat is stuck closed then that might pressurise the system leading to leaks or head gasket issues. But there has been no leaking of coolant since the first time this happened several months ago and it appeared the header tank was overfilled. The coolant level has not changed since.
Just thinking that the fan should not run before the thermostat has opened. Don't know how that's controlled though.
Anyone got a similar experience or have a clue what's going on?
Cheers
Alan
Cheers
Alan
